OK, I see.
My suggestion is that you answer top management "Whatever the number is, it will always be too much for you guys" :) Just kidding. .......But, it may be true.
But, it is an interesting question.
In my experience the waste often lies in not executing "the basics" to their potential. Mainly improving execution of Preventive Maintenance and work management (supporting processes such as materials management, correct technical data may influence as well). But, it may not be true for you, I don't know your plant.
Looking at it the way you suggest would be interesting, but I think it will be a lot of work to get you the answer. Doing it that way you will research the end result, the cost... of course you may be able to dig backwards and get to the answer as to why the cost is there. Somehow you need to find the sources to "what drives the cost", the spending itself will not give you that answer. So in your example with the generator, you will need to find the causes as to why the plant spend $X, once you find the failures, you need to find the technical root cause, but also the human cause and the systematic causes. Good if you can do it, but it will take a lot of time.... A lot!
If you instead assessed your "work systems" (most likely cause), you will get to the causes quicker, I think. You won't have to research every failure, you can assess the work process and see that..... for example, lubrication is done poorly. If it is, you KNOW that poor lubrication practices will cause a lot of premature failures. This is just an example, perhaps your lub program is great. But, it is very easy to assess. Check how lub is handled stored and applied.
Best of luck, feel free to connect if you would like to discuss.
Torbjorn Idhammar
President & CEO
IDCON, Inc.
http://www.idcon.comRaleigh NC
Sent: 01-31-2022 02:32 PM
Subject: RAV Calculation for Existing Asset
100% agree with you, Torbjorn!
What I am trying to do is to design a formula tells us how we far in our MC! In other words, I would like to answer the controversial question related to "why you spend too much in Maintenance OPEX?!" As a technical team, we used to receive such questions from the business OR the finance people.
I hope you got my points.
regards,
Samih
Samih Abdalazeez
CMRP
Assistance Maintenance Manager
Sent: 01-31-2022 02:09 PM
Samhi,
I don't feel the MC vs. RAV should be used as a budgeting tool for each equipment.
I see the MC/ RAV as an outcome of everything we do and that it is an average for all equipment in the plant. Why I say that is that if you have a breakdown, or failure of the equipment, you have to fix it, a maintenance job can't be avoided (unless you don't need the equipment and then you should take it away anyways). Also if there is a required PM, I don't think you would stop doing it because you meet a certain number.
Torbjorn Idhammar
President & CEO
IDCON, Inc.
Raleigh NC
Sent: 01-31-2022 01:53 PM
Referring to the Best Practice Benchmark, Maintenance Cost as a Replacement Asset Value (RAV) percent should be between 2-9%! Now the question is, what is the most proper approach to calculate the same? Shall we identify the maintenance cost limit in the first place of the asset`s installation? Or we shall keep spending on maintenance until reaching the 2-9% limit and then stop?
For instance, let us suppose that we have Supply and install one power generator by $1,000. The first approach says that I shall secure only $90 for the maintenance for the coming 5 Years (Asset Life Cycle - ALC)! The second approach says that, we shall keep spending on the required maintenance until reaching the $90 (whenever we reach).
What do you think about the above two approached? What is the right one?
Samih Abdalazeez
CMRP
