Dear Lesiba,
The case is interesting, and ultimately the contributions and comments from the colleagues is very good. On the other hand, I can share my own experience in the failure of a band, I suggest, like the colleagues, to evaluate the following:
1. Operative: Loads, sudden changes
2. Equipment: Cleaning system, rock encrustation, presence of metal, protection system against metals. tensioning system, age of the band, lifetime of the band.
3 Routine inspection: Scope of inspection, in the splice, band seals, wear rate, openings, detachment, rubber cuts and types of cut, follow-up to observations.
Regard
Vladimir Tasayco
Vladimir Tasayco Sanchez
Colón
Sent: 04-21-2023 02:10 PM
Subject: Conveyor Belt Damage
Hi Shelton
It ripped across the belt. Yes there is a metal detector before the crushers but not after on the very belt.
Lesiba Moja BEng
Reliability Coordinator
First Quantum Minerals
Kempton Park
Sent: 04-07-2023 03:07 PM
Hi Lesiba,
Did it rip along or across the belt?
I once experienced a similar case of a belt rip due to a collapsed pulley which then went on to cut the belt along as it moved. Also, another cause of the rip could be tramp metal cutting the belt, do you have any metal dictators installed to detect such?
Shelton Ndlovu
Assistant Reliability Engineer
Glenrise Investments
Bulawayo
Sent: 04-06-2023 06:38 AM
Greetings Fellow Practitioners
Last week I had a scenario whereby a conveyor belt ripped in half causing a major down time. I've been tasked with the RCA but can't wrap my head around what could've caused this.
Any one experience this?
