Alaa,
My understanding of your question is that you are asking if there is a defined time window, following maintenance work being completed, that defines equipment failure as Rework. In my experience the answer is no. If the equipment fails, after maintenance, in a time significantly less than the expected time it should operate with our failing, it may be a Rework case. The cause of the failure is important. If the equipment fails because of an operator error or some external cause (e.g. lightening strike) then it is not Rework. If the equipment that was worked on fails due to not being reassembled properly, use of the wrong replacement part or due to internal contamination those would be Rework. The Root cause might be a lack of documented spare parts, poor documentation in the maintenance procedure (if there is one) or lack of sufficient training for the personnel.
In the end, the Cause of the failure is what the people responsible for Reliability can address, whether it is Rework or not. The Rework metric should draw managements attention to the Cause so that mitigating actions can be taken.
Best Regards,
Roger Shaw
APM Consultant
Salem CT
Roger_Shaw@comcast.net------------------------------
Sent: 11-14-2025 06:08 AM
Subject: Equipment Rework
Dear members,
Subject equipment rework term us important KPI.
An equipment repaired and it failed due several reasons such as wrong assembly, wrong operation, or materials quality.
My question when I consider the rework for the trending, is after a week from start up, a month or 3 months etc.
Any practice guidance for this? Hope my message is clear
Thank you
