I agree
Every engineering system is meant to operate at a certain level of quality, which is described by the manufacturer.
This level of maintenance is achieved if the manufacturer's procedure and specifications are abided by.
Systems are not designed and manufactured 'fool' proof. What I mean is negligence of maintenance personnel to do the right thing doesn't yield to avoid good quality; it will break down.
You could perhaps advise the client on the need to carry out precise fastening, lubrication routine, alignment and balancing, which basically minimizes unwanted vibration to minimize wear.
Preaching FMEA and RCA to frontliners so 'we' understand where most breakdowns emanate to prevent them can keep plants operating in close tolerance to required reliability.
For example, the fault tree analysis can be used to explain to personnel how most big problems are caused by little things(mostly bad FLAB).
Darlington Asomaning
Field Service Engineer
Mantrac Ghana Limited
Darlington Asomaning BSc
Tema
Sent: 07-21-2023
Subject: FLAB and Precision Maintenance
Dear All
I'm a proponent of maintenance basics when it comes to getting your assets to deliver reliable service. Similarly, a correct troubleshooting process must first look for facts and relevant information concerning the problem.
I would like members to please correct me if I'm wrong. My view is that training frontline workers (more especially craft) on the importance of, and performing the correct fastening, lubrication, alignment and balancing of machines forms the basis of precision maintenance. If top asset managers/leadership claim successful implementation of precision maintenance and frontline craft workers have little or no knowledge about FLAB then there is serious misalignment, right? Consequently, any precision maintenance programme is bound to fail.
I would appreciate members' views on the correct approach to advise a client in this situation.
Thank you in advance.
Boykie Sebobi CEng MIMechE CMRP
Principal Consultant, Asset Management
Innolead Consulting
Gaborone Botswana
<quillbot-extension-portal></quillbot-extension-portal>
