We had a H-Frame or lift frame failure on a Large Wheel Loader CAT-994K. The frame failed The frame failed by shearing about 500 mm from the left hand pin to bucket connection. There appears to be no indication of cracking prior to failure. There are signs under the lifting frame that indicate contact with truck trays.
If anyone has had similar or related learnings to share I'd be very grateful.
