HI Lesiba,
I'm guessing you're having issues with your liner bolts on your discharge end (vs the shell / girth gear studs)? I agree with Kamaria and Randy. Most of the time these are due to preload issues during installation. It's fairly common practice to "re-torque" the liner bolts after around 24 hrs of operation. That'd be my first check.
If it's only on the discharge end, it may point to some other issues. Have a look for washout of the mill shell behind the liners during the next reline.
There are a few products that can help monitor these issues too, enabling you to act before the bolt breaks. "Smart" bolts with load cells inside the bolt are a good option here. There are a few companies with products in this area. BoltSense by Copper State is one I'm familiar with. Their product uses a bluetooth transmitter to send the bolt tension back to either a receiver or to a handheld device (e.g. cell phone). They have been used in exactly the application you've mentioned in the past and are a relatively cost-effective option.
Copper State Bolt & Nut Co. :: Load Monitoring Fasteners
This will only allow you to collect more data however, and obviously won't address the root cause of the breakages. Feel free to shoot me an email (or we can discuss here) if you'd like to chat further.
Benjamin Prior CMRP, BEng, MBA
Principal
Priority Consulting Inc
Berkeley CA
Sent: 09-21-2023 01:18 PM
Subject: Mill bolts
Would any of he members have experience in bolt breakages in mills?
Particularly on the discharge?
I ask because I'm currently study what could cause these "pre-mature" bolt failures
