  • 1.  New vs Refurbished materials sharing a SKU in CMMS
    Posted 03-11-2024 04:04 PM
    Greetings all,
    We have a difference of opinion among our different storeroom teams on whether a new part and a refurbished part should share a SKU or have separate SKU.
    I'd like to hear what you're doing in your company and regardless of which you've chosen one or the other, what were the primary drivers for the choice you made?
    Additionally, if there were any alternatives or mitigations that you've implemented and would be willing to share, that would be useful as well.
    As an example:
    Proposal 1 - 1 SKU and using 2 different bin locations to segregate the inventory along with physical tags.
    Proposal 2 - Implement serialized MRO
    Thanks.
    Glenn Simmonds, CMRP
    Senior Manager - Corporate Machine Reliability
    Sabert Corporation
    www.sabert.com
  • 2.  RE: New vs Refurbished materials sharing a SKU in CMMS
    Posted 03-12-2024 06:59 AM
    I think one SKU can work with different locations to specify both new and refurbished parts for ease of identification and application. Since the parts have the same description, one SKU is okay provided an additional identifier is included to differentiate between new and refurbished. Also, separate bin locations should be utilised.
    Alaba Olayinka Onasanya
    ExxonMobil
    Victoria Island
  • 3.  RE: New vs Refurbished materials sharing a SKU in CMMS
    Posted 03-12-2024 09:42 AM
    Hi Glenn,
    I have also seen where part condition is tracked, where each condition state has its own SKU or suffix.  Based on the defined process for parts you can then enforce the workflow of allowed conditions for a given part.  This can also be implemented with serialized MRO if needed.
    Luke Soltis
    Mgr
    Bearingpoint
    Chicago IL
  • 4.  RE: New vs Refurbished materials sharing a SKU in CMMS
    Posted 03-12-2024 09:47 AM
    hI
    Since we need to follow up how long the refurbished component will last, we prefer to have separeted SKU, but utilizing the same Sku code and adding one " R "
    exemple : new one 1F32K
    refurbished 1F32K-R
    In a lot of circumstances we discover that a refurbished component will a higher cost per working hours that a new one > waste of money.
    Gilson dos Santos
    Director
    Curitiba
  • 5.  RE: New vs Refurbished materials sharing a SKU in CMMS
    Posted 03-13-2024 12:26 PM
    Depending of the level of tracking you want, different options are available:
    1 - Merge new and refurbished material under a single SKU using split valuation. Part retrieve from the store will have the average moving average price
    2 - Assigned different valuation class to the SKU: New, refurbished, damaged, crash spare. More challenging to make sure proper valuation class is assigned on the good issue.
    3 - Serialization will allow to track full history of the specific material but is a lot more demanding to maintain properly.
    Do not recommend to use different SKU as it make maintaining BOM difficult. Trades and planners will also forget to search if a second SKU exist for the same item or two update both if some characteristics change
    Considering benefit vs effort, use more option 1 which allow to benefit from the lower cost of a refurbished material without the associated clerical burden. Option 3 to be considered for critical and expensive component only.
    Charles Henault
    Senior Advisor – Asset Management
    Riotinto
    Montréal QC
