Hi Vikas, as Andrew already mentioned this is really up to you how you define your implementation of the 10% rule as it is not a hard and fast rule, just a good practice. My recommendation would be not to be too fussed about whether it is +/- 3 days or +/- 1.5 days. Choose something that is supported and practical for your organization and make sure that you keep in mind:
- any regulatory considerations i.e. is it OK to do regulatory PMs 'late' compared to your schedule date? that might depend on the regulator, your company policies and whether your scheduled date takes into account the 'float' your allowing
- what you do with PMs on extended frequencies e.g. Pms on a 4 yearly interval, that is 1460 days (or 1440 if you use a 360 day calendar) and a +/- 10% allowance would allow doing the work 140 days early or late. I was never a big fan of that, so I always advocated a maximum +/- float of 30 days. That does mean you need to look ahead through a longterm schedule and move thosekind of PMs in your CMMS so they come out in the right period
Erik Hupje
http://www.roadtoreliability.comhttps://www.linkedin.com/in/erikhupje/------------------------------
Sent: 07-29-2022 11:29 AM
Subject: Preventive Maintenance
Can anyone clarify about the 10% rule of Preventive Maintenance. If it is 30 days PM then total 3 days on either side are allowed or 1.5 days on either side.. means can PM be performed between 27 to 33 days or 28.5 days to 31.5 days??
