I'm not familiar with crusher designs but a few general thoughts on failure.
If I understand your failure mode correctly, it is shaft fracture from fatigue?
1) Equipment should be designed for infinite fatigue life. Components fail from fatigue from usually two main sources - material defect or a high cyclic stress. There are many branches under those two, but dial in on those on your design and operation and somewhere below that you will find your answers.
2) If you can access the shaft fracture area easily there are several methods that can work - dye penetrant, magnetic particle, ultrasound might could be used from end of shaft to find larger cracks. Fatigue cracking will typically start at the surface.
3) If the shaft is fractured, I don't know any way to repair the shaft. You need a new shaft.
4) If you have the shaft design or an old shaft, any good machine shop can make you one. Be sure to make sure you have as much of specifications as you can around material and detail designs. Likely there may be areas that need a design improvement if you are having failures. Don't just fix it, improve it and solve it.
Good luck.
Sent: 01-25-2024 03:35 AM
Subject: Primary Crusher - Main Shaft Failure - Kawasaki KG 15522
We recently experienced main shaft failure on our crusher. Initial indications are that this is a fatigue creep failure on the top end of the shaft. We are reviewing all critical components and spares as a consequence of the failure and I would like to tap into knowledge base of this forum with a few questions:
1) What is the expected useful life on a main shaft? In fact what is overall life expectancy on an entire crusher circuit? We are engaging OEM representatives as well, but they are slow to respond.
2) what potential NDT technique can be employed to routinely inspect shafts for potential failures?
3) Can a main shaft be repaired successfully to 70-80% useful life of a new shaft as an emergency spare? What procedure to repair would be followed?
4) Can 2nd hand shaft be sourced any company recommendations?
Looking forward to hearing from you
Charles
