  • 1.  Realibility calculation
    Posted 04-11-2025 07:39 AM
    Hello, Dear Community. Can someone help me with reliability value calculation over the engineering calculator. Let's see below example:
    My question is, how to calculate reliability using manually engineering calculator, can smn show the sequence.
    Akif Najafov
    Business Excellence Supervisor
    Socardownstream
    Baku
  • 2.  RE: Realibility calculation
    Posted 04-14-2025 10:13 AM
    1. Multiply λ by t:
      • 1.05 × 10⁻⁴ × 1000
      • On calculator:
        1.05
        EXP or ×10^x button
        -4
        1000
        You'll get: 0.105
    2. Make the result negative:
      • Press +/- or use (-) key
      • Result becomes: -0.105
    3. Exponentiate:
      • Press e^x or EXP or SHIFT + ln (depends on your model)
        If SHIFT + ln, press:
        SHIFT
        ln
        -0.105
      • You'll get: 0.9003 (approx)
    Lokesh U
    Packaged App Development Senior Analyst
    Accenture Solutions Pvt Ltd
    Chennai
  • 3.  RE: Realibility calculation
    Posted 04-18-2025 03:34 AM
    Thanks a lot for the help. Appreciate.
    Akif Najafov
    Socardownstream
    Baku
  • 4.  RE: Realibility calculation
    Best Answer
    Posted 04-14-2025 11:16 AM
    105/1000000=0.000105*1000=0.105
    0.105 press on calculator +/-  valve will come like that (-0.105) then you have to press eˣ and valve will come e^(-0.105) after that you have to press = 0.90 after that convert into percentage 0.90 *100=90%
    Tauqeer Haq
    Maintenance Superintendent
    Saudi Industrial resin
    Al Jubail
  • 5.  RE: Realibility calculation
    Posted 04-18-2025 06:49 AM
    Thaks a lot, Sir, appreciate your full answer.
    Akif Najafov
    Socardownstream
    Baku
