Hello all,
I will appreciate if anyone can assist with this.
I am looking into replacing a destoner in our food processing facility due to significant issues with its reliability. Regarding meeting demand (or desired throughput) of 20,000kg/hrs., that has never been a problem, but in terms of maintainability, the rate of maintenance head cost, downtime, has been skyrocketing for the past 5 months.
To cut the long story short, the present destoner has deteriorated to the extend that the only solution will be to replace with a more reliable one.
Will appreciate if anyone can recommend a couple of destoner vendors (within Canada or north America preferably). After which i will like to access the vendors functional design specifications/modules (Design capacity, application(s), layers of separation, working principle, motor(s) + instrument(s), foot – print, & reliability).
present destoner spec:
Capacity (max) =
20t/hr.,
Description of deck & frame: Basic steel frame,
Footprint: 3315mm [L] x 1994mm [W] x 2785mm [H].
Thanks and Best Regards
Oluwadamilola Olatunji PEng
Roquette Canada Limited
Winnipeg MB
