  • 1.  Vertical Turbine Pumps PM
    Posted 05-29-2023 10:56 AM
    Hi Everyone,
    I would appreciate if anyone is willing to share a sample preventive maintenance check list for vertical turbine pumps - rating of 1500HP.
    I’m trying to compliment the existing PM program I’m developing.
  • 2.  RE: Vertical Turbine Pumps PM
    Posted 06-06-2023 11:55 AM
    What is the service environment for these turbine pumps?  Are they being used for de-watering?  Have you checked with the OEM to get their recommendation?
    Marc Laplante
    Asset Management Principal
    Roanoke VA
  • 3.  RE: Vertical Turbine Pumps PM
    Posted 07-06-2023 08:35 AM
    My experience has been activity is mostly centered around condition monitoring - vibration analysis in particular.  After that I have typically seen a definitive wear out time frame on the pump - bearings, shaft and impeller so that a target changeout time might be targeted.
    Aside from above, a few other things to check on a routine.
    • Packing adjustments or repacking.
    • Motor lubrication
    • Verifying or resetting impeller clearance on occasion.
    • Could check pump performance (flow, pressure, motor load) to note wear.
