  • 1.  Electric Motor Storage Requirements
    Posted 06-02-2021 06:51 AM
    What should you consider when storing an electric motor?
    How should it be stored?
    What maintenance tasks should you perform and when?
    Timothy Rice
    The Defect Elimination Project
    Salt Lake City UT
  • 2.  RE: Electric Motor Storage Requirements
    Posted 06-02-2021 09:06 PM
    There’s a good presentation from an SMRP Carolinas Chapter meeting from maybe 2017 that covers a motor reliant program from a paper factory. They improved storage: clean, away from sources of vibration and vehicle dust, shaft out with a dot on the end of the shaft. They rotated the shafts 1 and 1/4 times a month. They also did MCA on receipt of motors and before installation. They had balancing requirements for fans and the pump end.
    Solvay, Inc
  • 3.  RE: Electric Motor Storage Requirements
    Posted 06-03-2021 12:11 AM
    If HV motors, this will require proximity to power sources for the dehumidifier heaters.
    Tee Yeow Hum
    Shell
    Singapore
  • 4.  RE: Electric Motor Storage Requirements
    Posted 06-03-2021 09:36 AM
    Just a few quick things I've seen as best practices.
    • Rubber pads stored under motor for vibration dampening.
    • Climate controlled storage environment (low humidity) to combat corrosion.
    • Rotate shafts quarterly several turns with multiple of at least 1.25.
    • Protect shafts with a corrosion preventative coating and wrap to prevent shaft damage.
  • 5.  RE: Electric Motor Storage Requirements
    Posted 06-04-2021 02:03 PM
    1. Keep anti-condensation heater in ON condition.
    2. Rotate the motor shaft at quarterly
    3. Protect shaft from corrosion
    4. Ensure storage area is humid free, if required provide plastic cover or sealant to flange joints/terminal box etc.
    Ashvin Parmar
    Reliance Industries Ltd
    Jamnagar
