Your scheduled PM dates should not be moved for simple convenience (Or for any reason, for that matter). If you move the dates, as others have said, you send the message that the schedule is not important, and this undermines the whole PM program.
There is a reason for regular, systematic inspections, and changing or moving the due dates makes a hash of the program.
In a previous life, if the PM was not performed in a timely fashion (established and communicated to all) it was canceled with a justification noted.
Everything we do should be used to drive improvement and reliability, even our failures! When we do not accomplish our goals, this needs to be documented, and used as an opportunity to improve (Not just point fingers). If the machine that did not get inspected, experienced a failure that should have been caught on the routine inspection, this needs to be communicated, and used to further support the program.
David Rempel
RELIABILITY PROFESSIONAL
Allied Reliability Group
Houston TX
