Hello Jason,
It is refreshing to see at a minimum, a criticality analysis performed. I hope it was part of a greater FMECA effort. As a general rule of thumb, PdM is assigned to critical equipment as part of their regular maintenance routine, in addition to any other recommendation emanating from SME's. We have three classifications of criticality, hence the ABC record rating at the equipment level. We employ a comprehensive suite of PdM technology, most of it performed in-house. The are:
- Partial Discharge Analysis - semi-annually and combined with rotor flux analysis on large generators (power industry), buss bars
- Rotor Flux Analysis - semi-annually
- Vibration Analysis - quarterly, apply this to pump, fan, blower assemblies, not individual components
- Infrared Spectroscopy - annually, apply this to circuit breakers, and even rotating element bearings, air-cooled condensers (yes-really)
- Motor Current Analysis - semi-annually, either static or dynamic testing to fit plant outage schedule
- Megger/Polarization Index - anytime a machine is taken out of service or worked on
- Lube Oil Analysis - much too involved and detailed required to adequately expound on within this venue. We have test slates which are site/equipment specific. These are deployed using strategy-based PMs within SAP PM
- Transformer Oil - DGA performed on all GSU's regardless of criticality - due to the logistics of procuring one if one failed given persistent supply chain issues. Since the inception of this program, we have installed Serveron on-line DGA monitors which have proven themselves valuable for transformers in remote areas.
- High Energy Piping - annually
AND Ultrasonic Testing - typically used in conjunction with other PdM technologies, ei - IR when troubleshooting transformer bushing issues, or steam condenser vacuum problems....hugely under-rated PdM technology tool.
You can use discretion when applying PdM such as for motor MCA - use on motors:
- which operate at higher voltages of 600V or greater
- do not have redundant functional capability
- are of an unusual frame type or other constraint which will require rewinding in the event of failure and thus lead to lengthy down time
I agree with the small quantity of oil components. Just replace the oil at a given interval, preferably based on usage and maybe spot-check it occasionally just to see what wear particles you have and whether or not the additives are holding out ok. Best to replace early rather than late. I am sure I missed a bunch.
All the best with your maintenance strategies
Ed Espinosa, CMRP, CRL, PMP
Asset Management
Puget Sound Energy
Sr. Performance Analyst
Puget Sound Energy
Bellingham WA
