We only use auto greasers in locations, such as screw conveyors, where any excess grease is useful for keeping contamination out of the bearings. Wherever possible, we use ultrasound-assisted greasing instead. Someone listens to each bearing with ultrasound, and grease is only added if it is needed. This approach has two benefits. One, the bearing gets exactly the amount of grease it needs. No more, no less. And two, someone listens to every bearing, so we catch any developing failures early. If we come across anything questionable, we can double-check it with vibration analysis to determine what the fault is and how severe it is.
