Most will use the OEM recommendation but I have found most of these to be overkill and not a best practice to follow. Like others have mentioned, I rely on predictive maintenance technology - vibration, oil analysis, temperature, etc. to help set intervals for oil changes. I work in pulp and paper but the equipment is near the same for oil and gas.
One example of what I'm talking about. Many pump OEMs say change oil at 2000 hours (every quarter). Unless you have a contamination or severe temperature issue, this is way too often. I've repeated several studies on pump lubrication change intervals and found the following. With good pump operating conditions operating a synthetic oil, I had no lube oil degradation after 2 years of operation. I never pushed intervals beyond 2 years but set the standard for pumps on synthetic oil at 2 years oil change unless there were contamination or other issues observed. It is not practical to do oil analysis on pumps due to the low volume of oil.
I'd advise a similar approach to any oil change interval. Study the equipment and put reliability checks in place to set intervals.
Great topic for discussion.
