Also since both pumps are doing the same, it is likely a system problem. Just to make sure, verify the correct impeller is on both pumps. Same flow but higher system pressure and more HP is required. Efficiency changes too.
Ok, so taking a quick look at the pump curve I see the following.
At 96m3/hr, 64% eff, 30Kw
At 124 m3/hr, 68%eff, 34Kw
With 11% increase in density that makes up the 4Kw difference and basically they are the same pumping condition power wise.
I don't know what motor size you have so not sure of FLA and any other motor size issues. I'd check motor voltage too just to make sure. Low voltage will mean higher amperage for same power. Check wiring and starter connections.
Sent: 05-09-2023 11:53 PM
Subject: Centrifugal Pump increased power consumption at reduced flow rates
Thank You Mr Randy for sharing your feedback.
Yes, we identified that the increase in density is one of the reasons of motor overload. operating liquid density from 646 Kg/cubic m to 720 Kg/Cubic m which corresponds to a significant increase of 11.5%
Recirculation valve isn't passing.
We haven't checked viscosity part
Issue is motor overload trip on FLC (problem is current consumption. Motor is drawing more current even when pump is operated well below rated point. Please refer attached curves.). Current operating point is 96 m3/hr
Vaibhav Sharma BTech
Saudi Aramco
RAS TANURAH
Sent: 05-08-2023 08:47 AM
I am not familiar with naphtha but a few other random thoughts.
With SG increase, you are 1.11 times more BHP to start.
Pump clearances can cause that but you say they have been checked and are correct.
Assume pump turns freely by hand when down and empty.
Check system for any recirculation valves open or leaking by which is not measured flow in system. Is the flow you list from a flowmeter or from curve or calculation?
Is viscosity in range for design? Has it changed?
Is issue high power or high amperage?
What is motor voltage? If line voltage is lower, amps may be higher for same BHP.
Can you check system pressure compared to original design? Does it match up with your flowrate or motor load?
