Funny this came up recently in a conversation with some maintenance leads.
If you have a good vibration analysis and predictive maintenance program, it will find misalignment fairly easy. If you are having running equipment get misaligned after operating some period of time, there is another fundamental problem - baseplate, installation, etc.
Doing a hot alignment to deal with thermal growth is about the only time I might go back and realign outside of letting my vibration analysis dictate the need.
I've observed OEMs sometimes go overboard on PM checks. Many still have in their manuals to change oil every 2000 hours but that is extreme overkill. I've done oil analysis on pumps running synthetic oil after 2 and 3 years with no degradation of the lube oil.
If you did start down that road of some routine alignment, if you didn't find it misaligned in 3-4 times, you should extend and quite the process. If you do find something misaligned every time, then some RCFA needs to be initiated to find out what the root causes are.
Good question.
