Hi dear all
May be this topic has already been covered but I am posting it again.
Working within the maintenance of heavy equipment and in order to implement a CMMS, I would like to know if:
1. there is a standard template of codification and naming for the different module a CMMS can have like maintenance ranges, preventive maintenance activities, correctives activities and basics TPM activities.
2. Is there also a template of procedure or operating mode for preventive and curative management?
3. And finally, if there is a template or standard of codification to define a root cause tree: like symptoms, causes, remedy. (For this last point I can check in the part books of the equipment to find insights, but finding a common core for codification will be helpful).
These coding conventions if followed would be helpful for proper and good implementation of the CMMS. Any support is welcomed.
Thanks in advance for you reply.
matt alonzo
Montpellier
