Thank you so much.
I know the time will base on these factors like maintenance staff numbers, staff proficiency, and task package,etc.
And SMRP world-class is 50~55% wrench time, I will consider the different factors to arrive the goal.
Yi Sun
Huizhou
Sent: 08-07-2023 01:12 PM
Subject: Planning Knowledge
Hi,
Unfortunately, each task procedure may vary across facilities. I can suggest that since you know the procedure, engage the maintenance technicians to help determine the estimated time. Depending on their personalities you may have to observe the task execution in person to record times but If there is a technician who is experienced and approachable you may be able to ask.
Regarding books: look for anything indicating wrench time etc. also, see attachment.
KAMARIA DUNCAN
Mechanical Technician III
P.P.G.P.L
Point Fortin
