Hi Hayden, sorry for leaving this unanswered for so long. I apologize.
It might be useful to have a 30 min discussion over a Teams meeting. I could run a few things by you to see what makes sense. I could help with some ideas on how to, as you say, "low key pitch". The "seven questions" approach could be helpful for just that.
As far as libraries are concerned, there are a few out there. In the past I've worked with the APT library (which has been acquired - need to verify who acquired them). We have one that I could show you so you can decide if it has the right asset types for what you're trying to accomplish.
55001, 8.3 - spot on. The "shall" statements in this clause are meant to point out protections that are needed to reduce the risk of the failures you originally described.
Please let me know what you think. Let me know if you have some time over the next couple of weeks for a 30 min Teams meeting.
Marc Laplante
Asset Management Principle
Committee Member ISO TC251
Itus Digital
Charleston, South Carolina
mlaplante@itusdigital.comwww.itusdigital.com------------------------------
Sent: 06-07-2023 11:30 PM
Subject: Risk Management for Maintenance Tasks
Thanks for responding Marc. Your initial analogy is correct, and the steps you've outlined are helpful. I've spent some time thinking on how to low-key pitch a SAMP where there is not organizational support for that (at least not as such). I agree having that would drive other activities, so I'd be interested to hear any thoughts you have on that.
Regarding the third step you outlined, are there any specific tools that you seen successfully deployed?
I'd be interested to see the ISO guidance document when it is published - my initial thoughts on my approach were based on ISO 55001 8.3 and what I'd done in the past for ISO 9001 regarding outsourced activities.
Haydn Scott
Maintenance & Reliability Engineer
CertainTeed
Newnan GA
Sent: 06-06-2023 11:21 AM
Haydn,
I have worked with organizations that have restricted work on certain assets to be done by only qualified personnel - whether staff or contract. If your asset was an F1 race car, you won't be taking it to a local mechanic shop for corrective repairs, no matter how good their reputation. Sounds like this was a costly event. Clearly your asset, in this story, has high potential or actual value.
Step 1: asset management plan
This scenario puts light on an organizational issue that should be addressed by a simple strategic asset management plan. It doesn't require expensive consultants with endless stacks of post-it notes. A simple document and consensus is all that's needed. Also, no software needed other than what's needed to produce the document.
Step 2:
Compare your existing process to a generally accepted failure elimination work process to see if you're documenting this reliability event and asking yourself the right questions about the loss itself, the event data, RCA, failure mode review, strategy review, etc. Again, no software tools needed other than Visio or equivalent.
Step 3:
Tool - there are some excellent solutions and libraries available to help execute the strategy (step 1), enable the work process (step 2), and operationalize the strategy that is meant to keep these types of events from happening.
Hope this is helpful. Please let me know what you think.
For everyone's interest, ISO Technical Committee 251 is working on a proposed guidance standard called, "ISO 55012 - People involvement and competence" (which might address Haydn's question at a higher level).
Marc Laplante
Asset Management Principal
Roanoke VA
