Hi
I'm currently working on implementing vacuum compression on our gas wells, with a desired operating envelope ranging from -10 psig to 100 psig.
I would appreciate input from anyone with experience in vacuum compression applications. Specifically, I'm looking for guidance on the following:
Can a reciprocating compressor operate effectively within this pressure range?
What are the best practices for water separation in this context?
- How to manage dew point to avoid condensation?
How can oxygen ingress be prevented in a vacuum compression setup?
Are there any documented case studies or references where a similar application has been successfully implemented?
Any insights, experiences, or references would be greatly appreciated.
Thank you in advance for your support!
Syed Hassan Nasir Hashmi
Manager Reliability & Maintenance
United Energy Pakistan Ltd
Karachi
