Good day Dave,
Normally electrical control cabinets are designed with an IP rating which is "Ingress Protection" rating. It is an International Standard (IEC 60529) used to rate the degree of protection or sealing effectiveness in electrical enclosures against intrusion of objects, water, dust, accidental contact and vermin infestation. Check on the IP rating of your cabinets and upgrade them to the correct level for the conditions your electrical cabinets are exposed to. Water near electrical circuits should be avoided at all costs for obvious reasons.
My thoughts are, any other solution is just a band aid approach and therefore needs a longer-term solution, i.e., upgrade the electrical cabinets to the correct IP rating.
Whitey Seyanund
Adelaide, Australia
Pranildutt Seyanund MEM
Commissioning Manager
Hyde Park SA
