  • 1.  What is your Predictive Technology Program Strategy?
    Posted 05-12-2026 04:49 AM
    A successful Predictive Technology (PdM) Program Strategy is far more than simply collecting vibration readings or applying a few diagnostic tools to equipment. These technologies are important, but without a well‑designed strategy behind them, the program will flounder to deliver best practice results. Many organizations experience situations where a vibration analyst reports a problem, that is not acted upon with corrective action, yet the machine continues running for months without failing. This does not mean the technology is ineffective as it typically means the program lacks accurate baselines, clear decision rules, and a structured way to validate what the data is showing. In other words, the technology is working, but the strategy around it is not.
    A strong PdM strategy begins with clearly defined objectives. These objectives should explain what the program is trying to achieve in both the short term (such as reducing emergency repairs) and the long term (such as extending asset life and lowering total maintenance cost). To measure progress, the program needs well‑chosen KPIs/Metrics that help teams understand whether the program is detecting failures early, preventing downtime, and improving reliability. KPIs also support troubleshooting by showing where processes are working and where they need adjustment.
    The key objective a PdM program exists to understand the actual condition of equipment to capture defects early in the Performance/Failure Curve. Instead of relying on inaccuracy or guesswork or fixed schedules, maintenance decisions should be based on real operating data. This requires using the right technologies at the correct frequency, such as vibration analysis, ultrasound, thermography, oil analysis, and other emerging technologies to gather accurate information about how machines are behaving. The reason for the mention of emerging technologies is due to Machine Learning (ML). ML is good to develop along with automation integration (AI); unfortunately, companies have older assets requiring expensive sensor/software upgrades or infrastructures to "connect" to servers to compute the data/information. The focus should always be on asset condition and the most critical components and systems, because failures in these areas have the greatest impact on safety, production, and cost.
    To be effective, the program must detect failures early and reliably. This means establishing baseline readings, trending data over time, and comparing new results against known healthy conditions. As equipment ages or operating conditions change, procedures must be refined to ensure the program continues to provide accurate insights. This continuous refinement is what allows organizations to optimize life‑cycle cost, increase equipment capacity, and extend asset longevity.
    A common misconception is that doing more maintenance automatically improves reliability. In reality, more maintenance can actually make things worse. Assets that operate in a reactive state, where failures are addressed only after they occur, often suffer from poor or incorrect maintenance plans. This reactive approach can drive repair costs up to sixteen times higher than if the issue had been detected early and addressed through accurate planned maintenance. Lost production due to unexpected failures or limited access for PM/PdM work is often the largest contributor to these costs.
    On the other hand, performing too much maintenance can also be harmful. Overactive maintenance programs waste money, production output, resources and may even introduce new failures through unnecessary or improperly executed tasks. A practical rule of thumb is to adjust the inspection frequency for one legitimate failure discovery for every six inspections. This ratio helps ensure the program is neither too aggressive nor too passive. The ideal state is performing the right maintenance at the right frequency, guided by actual machine condition rather than arbitrary schedules.
    Best‑practice PdM programs strategically start by ranking equipment based on criticality, identifying which assets matter most to safety, production, and cost. Once criticality is established, teams analyze failure modes for each asset, including those that are difficult to detect. This analysis helps determine which maintenance strategies and PdM technologies are appropriate. For example, some failures are best detected through vibration analysis, while others require emerging PdM technologies including ultrasound, thermography or oil analysis. Matching the right tool to the right failure mode is essential for accurate detection.
    Program procedures must outline how equipment will be monitored, how data will be collected, and how often inspections will occur. Standardized data collection ensures consistency, while efficient routes help technicians gather information quickly and safely. Data trending, analysis, and reporting should integrate with the organization's CMMS so that program costs, benefits, and work orders are clearly visible. This integration also supports planning, scheduling, and long‑term budgeting.
    A strong PdM program requires clear Organizational support, Communication plans, Stakeholder management, Leadership support and accessible documentation. Everyone involved, from technicians to leadership, should understand the program's structure, roles, equipment needs, IT requirements, training expectations, and contractor support. Without a strategy and organizational buy‑in, even the best technical program will struggle to move beyond very basic functionality. Leadership support is especially important for ensuring resources, training, and compliance.
    Defining roles and responsibilities is another critical element. A RASI matrix (Responsible, Accountable, Support/Consult, Informed) helps clarify who does what, preventing confusion and ensuring accountability. Sites must also understand how each technology should be applied and develop procedures for fault identification, repair reporting, communication, and integration with maintenance work management.
    Training standards must be established so personnel understand how to collect data, interpret results, and respond to findings. Reporting requirements should be clear and consistent. Action thresholds must also be defined; for example, repairing critical faults within two weeks, addressing moderate faults within one month, increasing monitoring for minor issues, and taking no action when no faults are detected. These thresholds help ensure timely and appropriate responses to equipment conditions.
    A successful Best-Practice Predictive Technology (PdM) Program Strategy requires all of these elements with detailed steps that collectively determine whether a PdM program becomes a high‑value, sustainable part of the maintenance total reliability asset management strategy or remains a basic, underperforming effort.
    Ultimately, developing a Best‑Practice Predictive Maintenance Strategy; supported by strong leadership, program buy‑in, and consistent compliance… creates the foundation for a high‑performance maintenance program that improves safety, reduces cost, increases asset uptime, and extends asset life.
    Terry Alexander
    Life Cycle Engineering
    Charleston SC
    www.LCE.com
  • 2.  RE: What is your Predictive Technology Program Strategy?
    Posted 05-13-2026 11:35 AM
    Terry,
    You have created the best PdM strategy statement I've seen in my over 60myars of practice in this field. Well done!
    Jack Nicholas P.E. (Retired) CMRP (Retired), CRL (Retired), IAMC, CAPT USNR (Retired))
    Author , Keynote Speaker and Former CMRP Exam Director
    DBA Jack R Nicholas, Jr.
    Gettysburg PA USA 17325
    jdnicholas@supernet.com
    717-338-9166 (Home/Office/Recorder)
  • 3.  RE: What is your Predictive Technology Program Strategy?
    Posted 05-13-2026 12:16 PM
    Thank you Jack.
    Having taken a maintenance team from being 85% plus reactive to 82% proactive (correctly applying a strategic PdM program), as a major factor; Is an experience many have not seen. Our assets performed above standard, our safety improved ten-fold, we focused on corrective maintenance and eliminating inherent defects, and most of all operated as a profit center.
    Thanks again for your comments, greatly appreciated.
    Thank you
    Terry Alexander CMRP - REC
    717-421-7997
  • 4.  RE: What is your Predictive Technology Program Strategy?
    Posted 05-15-2026 05:01 AM
    Thanks Terry to share this knowledge. It is very true your words. I would highlight that, discipline is also a key factor for the proper implementation of a good PdM.
    Miguel A. M. Silva
    Global Maintenance and reliability
    Continental Tires
    Hannover Germany,
  • 5.  RE: What is your Predictive Technology Program Strategy?
    Posted 05-15-2026 08:31 AM
    Thank you Miguel
    You are so correct, having a team of well trained and qualified technicians; that truly are engaged, committed, and most dedicated, as you noted, really makes the activities "shine bright".
    Thanks again for the communication!
    Thank you
    717-421-7997
