Very good information. Thanks very much. They might be a few I could do some research on to get some great samples. I think that is what holds me back along, trying to get it perfect.
Sent: 10-31-2023 12:23 PM
Subject: Yearly Maintenance Plan Format
No need to start with a blank document. Any similar plants you can barrow from? Old plans for your plant, even if not accurate to your needs? If nothing else, find a template online from any plant. All those give you a starting point.
Do not attempt perfection. Create what you believe is 40% to 60% correct. Knowing you are wrong. Take your best estimate to management and production SMEs. Work with representatives from both groups together. Refine the plan until it seems about 70% or better. Minor maintenance, such as a sump pump replacement, you can probably plan 90% or better on the first run. An outage is weeks to months, starting around 60% and increasing while aligning with all teams and concerns.
Larry James
Lockout Larry
1. Personnel 2. Environment 3. Equipment 4. Revenue
Reno NV
Sent: 10-31-2023 11:56 AM
Good day Larry,
You really stated one of our biggest challenges in the O&M department. Sometimes one minor change in a contract can delay a major project for weeks. I will surely be looking into using MS Planner for our upcoming 2024 plan. Really appreciate the response.
Lastly, any tips you can give a young Maintenance Planner thats been tasked to bring fort all new maintenance strategies and plans to a company that have never before adapted to this approach to maintenance before. Our management now sees the need for it and want it but its never been done.
Thanks again, Mr Larry
Micah Thompson
Maintenance Planner and Outage Coordinator
Fortis Belize
San Ignacio
Sent: 10-31-2023 11:38 AM
Hi Micah,
As mentioned, CMMS are not good for communicating the plan. A Gantt chart or MS Planner are great tools I have used. Those and similar tools supply the ability to visualize the plan from the moment the first parts are ordered, the arrival onsite and the beginning of work. As a former O&M manager of several power plant types across renewables, including hydro, and carbon plants, it is always a challenge to get the purchasing and contract teams to understand the need to have orders filled on time. Gantt, Planner, etc. flow charts are good visual aids to understand the needs. Back those up with RACI matrices identifying personal responsibility, alerting people they are personally responsible for outage delays.
Your plan must include milestones. If the runner(s) will be removed and repaired, the vendor(s) supplying the services must be contracted to be available to arrive on the dates necessary. Arranging the contract must be included in the plan as milestones; search for vendors, receive bids, select, meet and great to discuss site vs vendor safety regulations, etc. If the runner(s) will be replaced, then lead time on the new runner(s) must be considered in the plan and include milestones to verify progress with the vendor. Planned: everything, parts, personnel, permits, etc., required for the work is on site or has a verified arrival date. Scheduled: After the plan is known and verified, set the dates.
Larry James
Lockout Larry
Reno NV
