Hi Shaun, I can't help but give you the most unsatisfying answer of all time: It depends. It depends on what you're trying to achieve, it depends on the timescales of the problem, etc.
A general rules of thumb about MTBF, as a metric, is: you should use if for long enough that you capture the time scales of the *relevant* failure modes you're trying to capture (eg: equipment that gets *touched* a few times a year requires a shorter time versus equipment that gets *touched* every several years), but short enough that you don't lose temporal trends - eg, my reliability significantly improved/worsened 2 years ago, but I'm calculating over 5 years so my answer is washed out. There's always a trade off to anything in life, and this is the general trade off I've learned from estimating a classic MTBF metric. But of course, it also depends on what you're trying to do with it too when you make decisions about what you want to trade off.
And that applies to departments or zones - it depends on what you're trying to do. And of course it also depends on the data as well. For example, If two zones capture data totally differently but my application is at the department level of interest, you may still want to look at the individual zones because combining the data may be nonsensical.
So, this answer is totally unsatisfying, but at least I hope I gave you some factors to consider in thinking about an answer.
Sarah Lukens
GE Digital
Roanoke VA
Sent: 10-25-2019 08:46 AM
Subject: MTTR and MTBF Measures
What is best way to measure MTBF? Yearly, Quarterly, and etc?
Also Automotive manufacturing, when measuring MTTR and MTBF on unit production not asset uptime. Where is the best locations to measure at, Departments or Zones within a department?
Shaun Dick
Equipment Reliability Engineer / MES SME
Honda Manufacturing of Indiana
Greensburg IN
