I agree
Every engineering system is meant to operate at a certain level of quality, which is described by the manufacturer.
This level of maintenance is achieved if the manufacturer's procedure and specifications are abided by.
Systems are not designed and manufactured 'fool' proof. What I mean is negligence of maintenance personnel to do the right thing doesn't yield to avoid good quality; it will break down.
You could perhaps advise the client on the need to carry out precise fastening, lubrication routine, alignment and balancing, which basically minimizes unwanted vibration to minimize wear.
Preaching FMEA and RCA to frontliners so 'we' understand where most breakdowns emanate to prevent them can keep plants operating in close tolerance to required reliability.
For example, the fault tree analysis can be used to explain to personnel how most big problems are caused by little things(mostly bad FLAB).
Darlington Asomaning
Field Service Engineer
Mantrac Ghana Limited
Darlington Asomaning BSc
Tema
