Hayden
Seen this type of issue many times. There are a number of possibilities.
- Age of systems - how long did they last?
- What was the consistency of the seals after failure (ie: were they sticky? brittle?)?
- Was the OD of the shaft correct and smooth where the seal was in contact?
- How many failures?
- Were the gear motors that failed all within the same age range?
- Motor and gearbox bearing fits at drive and driven (gearbox)?
A couple of images of the failure might also be helpful (ie: seal).
The lack of a hot spot/temperature and vibration may point us in the direction of lubricant compatibility if the number of failures are high. We ran into this about a decade ago when we were working on motor rebuilds for the US Navy radar gearboxes. They had specified an oil and had all of the seals changed to viton. The only warning of failure was motor failure or oil pouring out of the motors. During the RCFA we found that the (expensive) viton seals were not compatible with the oil. The lubricant company (customer service/sales) kept insisting that there was no problem until we were able to obtain the tear sheet on the lubricant which specifically stated that it was not chemically compatible with viton. We replaced the $35 seal with an $0.85 seal (I seem to remember it was buna, which was counter-intuitive).
Finally, the assembly process, if these failed relatively quickly, if when the motor shaft passes through the seal and the pinion is sharp, bumps the seal lip(s), or has burrs on it, can cause the problem. In this case the seal will still be pliable but would have what appear to be tears.
Just a few thoughts.
Howard W Penrose, Ph.D., CMRP
MotorDoc LLC
Lombard, Illinois
