Hi Lesiba,
This has been a passion of mine since the 1990's when I learned about the Physics behind Nord-Lock's Fasteners.
- Nord-Lock washers secure bolts with tension instead of friction.
- The system cannot loosen unintentionally as it creates a wedge-effect underneath the bolt head.
- Check Out the "Junker Vibration Test" U-Tube Video Nordlock uses to demonstrate and compare the results.
Specifically, regarding your question regarding preferences between Super Nuts and Hydraulic Nuts, the typical explanation (Source: GOOGLE AI) is:
- A "super nut" is a type of multi-jackbolt tensioner that uses a mechanism of smaller jackbolts to create a high clamping force on a large bolted joint with relatively low torque input, while a "hydraulic nut" utilizes internal hydraulic pressure to achieve extremely high tension on a bolt, often used for large diameter applications where high clamping force is needed without excessive manual torque; essentially, a super nut relies on mechanical tensioning with multiple small jackbolts, while a hydraulic nut uses hydraulic pressure to tighten the bolt.
- Nord-Lock also has a Solution - Super Bolt - which I believe accomplishes what you're looking for using the Nord-Lock Technology.
I've applied Nord-Lock as a Maintenance Supervisor, Maintenance Manager, Engineer, and recently incorporated Nord-Lock products into the Maintenance Strategy our Jacobs RAM Team prepared for the California High Speed Rail (CHSR) CP 2-3 Corridor - with a Prefix to all the Nord-Lock Maintenance Tasks being "NL-"!
Hey, I could be a Nord-Lock Sales Person, yet I just like to promote a terrific Product, built on physics, & TECHNICAL accuracy and precision! I remember when Grainger started to carry Nord-Lock (1990's I believe - prior to that you had to get these Fasteners from Nord-Lock directly). Wow, Nord-Lock just celebrated their 40th Anniversary in 2022.
I hope this is valuable for your applications, Lesiba.
Cheers!
Reliably,
Marie
Marie Getsug, PMP, CAMA2, CMRP/CMRT, CRL Black Belt, CPIP | Jacobs | Strategic Consulting - Asset Management and Senior Technical SME | marie.getsug@jacobs.com
PROVIDING STRATEGIC THINKING AND
PRACTICAL SOLUTIONS
Challenge Accepted!
Check out: RELIABLY© Check out: Jacobs - SI&A LG
Jacobs Graphical Failure Mode The Jacobs System Integration
Analysis & Connectivity System and Assurance Capability Site
Marie Getsug
Strategic Consulting - Asset Management - Senior Technical SME
Jacobs Engineering
Clarksville MD
