Hi Jesus, how are you?
There is a couple of things to check in the operational context to answer the question.
1. Are those external reasons unplanned?
2. Are those external reasons in a process upstream or downstream from the measured process or equipment?
3. Are those external reasons within the measured process or equipment?
4. Is the OEE measured at equipment, process, or line level?
To put it simply. Let's suppose we have a series process A-B-C, with 100% availability and quality =)
If the best or design capacities of A and C processes are 10. But the B process is restricted to 8 due to an external steam flow restriction coming from the utilities; the OEE would be as follows:
OEE Process A = 80% due to bottleneck on the downstream process.
OEE Process B = 80% due to external restriction on steam flow.
OEE Process C = 80% due to the upstream process restriction.
OEE Process A-B-C = 80% x 80% x 80% = 51%
I suggest looking at the process flow diagram and check the depth level for the OEE measurement. Then you can apply the same approach used for system reliability for equipment in series, parallel or partial redundancy, etcetera if necessary.
Let me know if you have any questions or need a quick chat.
Best,
Daniel Rojas
Guelph ON
