Expand all | Collapse all
Rotating assets
  • 1.  Rotating assets
    Posted 09-18-2022 09:38 PM
    Good evening all,
    I'm am currently working on the strategy for our rotating assets.  At what cost for a repair are you replacing with new instead of repairing?   I believe typical is 60% of new.  Also do you have all of your repairable assets set up as rotating assets or are there some assets that you simply repair and place back in inventory?  Obviously we have our motors, pumps, and decanter bowls set ups as rotating.  What do you do with smaller items such as valves and tank cleaning machines?  Thank you in advance for your feed back.
    Jason Resler, CMRP
    Corporate Reliability Manager
    Green Plains Inc.
    Omaha, NE
    jason.resler@gpreinc.com
    218-770-3719
  • 2.  RE: Rotating assets
    Posted 09-19-2022 06:30 AM
    Good evening Jason,
    When it comes to condemning equipment, I have always taken a life cycle costs based approach. For eg: if an immediate repair worth 60% of the price of new, ( material+labour) assures no major issue/expense for the next 5 years due to the known reliability of the parts used and the method of repair, then why not continue with the repair ? Such an approach would work for machinery with several sub-component such as pumps wherein one faces eroded wear rings in about 5 -10 years or worn casings due to an aggressive pumped medium etc. Valves on the other hand - I am not sure what kind of valves are these but it is again a call that needs to be taken based on the number of failures in the last 3 years/failure rates X cost of repair.
    If your business is the kind that suffers budget fluctuations in proportion to the market conditions and company revenue, it might not make sense to write down 60% as a fixed limit or company policy. When times get tough, every dollar matters and decisions tend to get more case by case...
    All the best.
    MATHEWS VADAKKAKARA
    MSPL Diamond PTE Ltd
    Bedford
  • 3.  RE: Rotating assets
    Posted 09-19-2022 07:58 AM
    Good point about the life cycle approach.  As for the valves my question is should all repairable items be a rotating asset?  Thank you.
    Jason Resler, CMRP
    Green Plains Inc.
    Omaha, NE
    218-770-3719
  • 4.  RE: Rotating assets
    Posted 09-19-2022 08:24 AM
    From what I've seen , the price goes up with the size of the valve and the country of origin. For the larger valves - DN 250 and above, the inserts tend to perish in 5 years, so I've made it a practice to stock the rubber inserts which, once replaced, are good to go. That way there is no need to replace the complete valve.
     Smaller valves on the other hand, upto DN 150 installed in critical piping, it might be economical to replace them every 2.5 years. I mentioned critical piping because the operator/maintainer might not avail shutdowns at recommended intervals to overhaul them. Such valves tend to wear/seize beyond repair in 2- 2.5 years.
    So you see, it has always been a case-to-case decision for me..
  • 5.  RE: Rotating assets
    Posted 09-19-2022 06:32 AM
    Yes, 60% is a number I've been given in the past, but be aware that the current supply chain situation has turned that rule on its head. There are a lot of things you just can't get new, or at least not for several months. One component I was looking into recently has a lead time of 1-1/2 years. Repairs and rebuilds have become necessary in many cases, with local machine shops custom fabricating replacement parts.
    For example, on Friday I visited our electric motor supplier, and they pointed out an overflow room full of motors waiting to be rebuilt. They are having a hard time getting new ones, so many more customers than usual are opting to rebuild motors that normally would be scrapped.
    Lafayette IN
  • 6.  RE: Rotating assets
    Posted 09-19-2022 07:47 AM
    I know what your talking about with today's supply chains.  I was talking with my motor rep last week about this question.  He told me that they have their holding lot for incoming rebuilds full.  He said that they are rebuilding motors down to 10HP even,  its crazy times.
    Do you
    Jason Resler, CMRP
    Green Plains Inc.
    Omaha, NE
    218-770-3719
  • 7.  RE: Rotating assets
    Posted 09-19-2022 07:31 AM
    We have gone to the 50% rule of replacement cost. We change out vales on regular basis, considering them as a wearable part, unless they are very large valves and it is more cost effective to rebuild then a couple of times before replacement.
    Kevin K. Heide
    Maintenance Supervisor  /   Haz Mat Captain
    Featherlite Trailers
    816 7th St W.
    Cresco, IA 52136
    P: 563.547.7304   F:563.547.7037
    E: kevin.heide@fthr.com   W: www.fthr.com
  • 8.  RE: Rotating assets
    Posted 09-19-2022 09:03 AM
    Jason
    Here is the program that we developed in the US DOE, which is the primary method still used today: Motor Repair Tech Brief (energy.gov)
    This is an article I'd written on the topic which fits today with availability of replacements: Motor Reliability | Electric motors: Repair or replace? Assess impact on production, reliability, suitability and cost | Plant Services
    And here are US DOE resources on rotating machinery (as well as other tech such as compressed air, steam, etc.) : Motor Systems | Department of Energy
    The guidance developed in all of these programs were from experts in the field combined with energy, academia, and national labs work.
    As for a rule of thumb - it generally fell between 60 and 80% of new.  Only in a few cases have I seen 50%.  The average was 70% the cost of new especially when upgrading energy efficiency.
    Hopefully you find this helpful.
    Howard W Penrose, Ph.D., CMRP
    Vice Chair Technical Standards wind, solar, energy storage, American Clean Power (formerly AWEA), and
    MotorDoc LLC
    Lombard, Illinois
  • 9.  RE: Rotating assets
    Posted 09-20-2022 08:52 AM
    Good topic and discussion.  I have seen over the years the 50% rule applied but I've never liked the rule.  It is too general and a bad guideline which doesn't take into account all the other factors such as life cycle, particular failure modes, delivery times, MTBF of asset, level and risk of repair, spares available, # of applications in service, etc.
    Consider this.  50% of a $3000 item isn't that much so just buy new, but 50% of a $50,000 item is $25,000 so would you rather throw away $25,000 to buy a new one?  I can fix and improve lots of stuff for 25K.  It really depends on the item.
    We have a gearmotor now that it cost about the same to rebuild than a new one, however, a new one is like 6-8 month delivery.  Our failures (multiple applications) come up in the 4-6 month range.  We really can't afford to wait for a new one all the time.​
  • 10.  RE: Rotating assets
    Posted 09-20-2022 09:07 AM
    Thank you all for your responses, this has all been good feedback!  Have a safe day.
    Best Regards,
    Jason Resler, CMRP | Reliability Manager
    Green Plains, Ottertail LLC
    Cell:  218-770-3719
    Email: Jason.resler@gpreinc.com
    www.gpreinc.com
    image001.png@01D85653.F6729B90
    Follow Green Plains: LinkedIn | Facebook | Twitter | Instagram
    CONFIDENTIALITY NOTICE: The information contained in this email, including any attachments, is confidential
    information and is intended only for use by those to whom it is addressed and may be privileged or otherwise
    protected.  If you are not the intended recipient, any disclosure, copying, printing, or use of this information is
    prohibited. If you received this information in error, please notify Green Plains via email at info@gpreinc.com
    ENTITY NOTICE: Green Plains Inc. owns its assets and operates its businesses through various subsidiaries and
    also seconds its employees to the general partner of its affiliated public company, Green Plains Partners LP. As
    such, neither the domain name, the signature block, or any other entity reference in this email shall imply such
    the employee is working for the entity so identified. Rather, the actions, authorizations, or statements made in any
    such email shall relate to the applicable Green Plains entity that is the subject of the contract or other legal
    document to which the topic relates.
  • 11.  RE: Rotating assets
    Posted 12-14-2022 09:53 AM
    Dear Jason,
    It's generally not a good idea to set a fixed cost threshold for deciding whether to repair or replace an asset. The decision to repair or replace should be based on a number of factors, including the expected cost of the repair, the expected useful life of the asset after the repair, the value of the asset to the organization, and any potential risks associated with the repair. For example, if a repair is likely to extend the useful life of the asset significantly, it may be worth doing even if the cost is relatively high. On the other hand, if the cost of the repair is relatively low but the asset has little value to the organization or is at high risk of failure, it may be better to replace it.
    Hasan Putra BEng
    Maintenance Planner and Scheduler
    PT Paiton Operation and Maintenance Indonesia
  • 12.  RE: Rotating assets
    Posted 12-06-2022 07:33 AM
    Dear Jason
    - If the M&R cost >50% of the Marketing Value (not the new value), If you can not estimate the marketing value, then you can calculate it as follow :
       Marketing Value = Land cost x (1- Age (Y) * .03 - .05)  ... 0.03-.05  according to the type of the equipment small or big , example Crawler crane with 10y , Marketing value will be approx. 70% of the land cost
    - Regarding to the repairable assets set up as rotating assets, It is according to your usage, we have both Fixed Asset (it have to be fixed back after repair) and Rotating asset which can be used wherever required after repair (but we have to update the location accordingly in the register.
    Hopfully to be clear
    Ahmed Hamed Abdelrazek Idris
    Asset Manager
    National Marine Dredging company
    Abu Dhabi
  • 13.  RE: Rotating assets
    Posted 05-03-2024 09:37 AM
    I am looking at rotating assets (Pumps, Heat Exchangers, Fans, etc. in a 2 asset system - where do I find the best practices for the timing of asset swapping?
    Andrew Piwowarski
    Facilities Corrective Maintenance Mgr.
    Wolfspeed
    Cary NC
  • 14.  RE: Rotating assets
    Posted 05-06-2024 08:01 AM
    Years ago I read an article by a motor manufacturer that recommended motors be rotated at least once a month while in storage, so that's the frequency I recommend for swapping online spares. (They also recommended the shaft be rotated at least eight times, to adequately redistribute the grease.) I apologize that I can't send you the actual reference that you're looking for - It's been so long since I read it, I don't remember what the specific publication was. If you search for motor storage recommendations, that may get you what you need.
