  • 1.  The Benefits of Preventative Maintenance Optimization
    Posted 12 days ago
    Preventive Maintenance Optimization or (PMO) is not only one of the best continuous improvement activities to implement, but also is important because it transforms your routine non-value-added maintenance from a generic expense into a strategic advantage, ensuring that maintenance efforts are as effective and efficient as possible.
    By using a data-driven approach & processto focus resources on critical assets and valuable tasks; organizations can significantly reduce costs, improve reliability, and enhance safety.
    The data driven approach most importantly includes recording, and using all routine, corrective, and reactive repair activity to understand failure's. Capturing accurate dates of all activities on the asset is crucial and includes knowing all labor and material used on the asset. This information reveals where the failures are occurring.
    Comparing this information to what is actually on the current PM can reveal gaps from existing PMs to what needs to be improved. By leveraging data and technology, such as Computerized Maintenance Management Systems (CMMS), organizations can automate scheduling, track performance, and continuously refine their strategy to balance efficiency and reliability for all assets.
    Enhanced Operational Efficiency and Cost Savings is a major benefit as: Well-maintained equipment that runs at peak performance, consuming less energy and delivering consistent output quality. PMO helps eliminate unnecessary maintenance tasks, ensuring that maintenance teams focus their time and resources on activities that truly add value.
    Significant Cost Savings: can be achieved by addressing small issues before they escalate into major failures, organizations can avoid expensive emergency repairs and associated costs like overtime labor and expedited parts shipping. It is generally accepted that reactive maintenance can cost three to sixteen times more than a planned, preventive approach.
    PM Optimization moves beyond traditional time-based maintenance activities' and identifies failures and materials used against the asset; and ensures the correct maintenance procedures, with the correct frequency will be performed, making reliability and longevity a reality.
    Terry Alexander
    Life Cycle Engineering
    Charleston SC
  • 2.  RE: The Benefits of Preventative Maintenance Optimization
    Posted 10 days ago
    Hi Terry,
    In your experience, how do you ensure that Preventive Maintenance Optimization (PMO) initiatives are truly data-driven and not just a rebranding of time-based maintenance?
    Specifically, which KPIs or decision criteria do you use to validate that PM tasks, frequencies, and material usage are effectively aligned with actual failure data?
    Luis Valencia Morón
    Gerente General
    Asset Healt Management E.I.R.L.
    Lima
  • 3.  RE: The Benefits of Preventative Maintenance Optimization
    Posted 10 days ago
    Greetings Luis,
    From an RE perspective developing a maintenance strategy is crucial for asset reliability. Many companies over look the value. My first check is to look at how reactive vs. proactive. I also compare existing KPI's with my own investigation. This identifies the existing conditions.
    Your comment on data driven requires investigation of maintenance records, how accurate and consistent. Are all assets listed in detail? With complete bill of materials. Is there a CMMS? What is the PM completion percentage? The CMMS is like a filing cabinet; if it's all in order or all not in order determines the amount of work required. Good record keeping is crucial for accurate PMO evaluation. Hopefully there are work order types: breakdown/reactive, corrective, and preventive/predictive. And captured accurate labor hours and materials used on the asset. To ensure a good PMO rebuild, all costs need identified and compared to the existing PM. So looking from a 50k foot level; good procedures and records are necessary and requires discipline. Of which why responded to the MTTR discussion as it is one factor in labor and material capturing. From this short explanation, do any thoughts arise? This is a topic, at least in my mind, from which at least 11 Reliability Engineering Processes can be examined to achieve reliability excellence.
    Terry
    Terry Alexander
    Charleston SC
  • 4.  RE: The Benefits of Preventative Maintenance Optimization
    Posted 2 days ago
    This is a great discussion, and I agree that PMO only delivers real value when it is anchored in how assets actually fail, not how often we assume they might.
    One limitation I've seen, even in organizations with disciplined CMMS use and solid KPIs, is the quality of pre-failure observations. If early condition changes lack context or consistency, downstream analysis may be technically correct but operationally shallow.
    When condition evidence is captured before functional failure, those points effectively map a failure timeline. That allows PM work to align with how degradation actually progresses, rather than relying primarily on calendar or usage assumptions. This is where PMO moves beyond interval tuning and becomes true failure-mode alignment.
    From a reliability perspective, that also reinforces PMO as a learning process, not a one-time optimization exercise. Curious how others have improved the consistency and fidelity of early condition data, since that often seems to be the limiting factor in practice.
    Nick Bell
    Founder
    Duallo
  • 5.  RE: The Benefits of Preventative Maintenance Optimization
    Posted yesterday
    This is a really insightful perspective,@Nick Bell. As someone that isn't a practioner like most of the group, this is the million dollar question I hear most often.
    In most cases, the production side of the house either isn't capturing data or has poor data practices/quality. Even in the instance where the reliability team has quality condition data, wouldn't it only paint half of the picture without contextual performance data from operations? Or am I thinking about it wrong?
    Steffen Katelouzos
    Solutions Engineer
    Advanced Technology Services
    Bristol VA
  • 6.  RE: The Benefits of Preventative Maintenance Optimization
    Posted yesterday
    Greetings excellent chat members: one of the first questions I ask is do you have a CMMS or file system that captures all asset data. Typically what I find today's companies that are or have limited staffing and are mostly reactive really don't have the time to even maintain their CMS or file cabinet in an organized fashion to really benefit them. It's not an easy task and it takes a lot of hard work and dedication, but the benefit is one of the best things you can do to take your Maintenance organization from a cost center to a profit center. I'm currently working on a few steps that are required for a good organized file cabinet or CMS that is most impactful for PMO.
    Thank you
    Terry Alexander CMRP - REC
    717-421-7997
  • 7.  RE: The Benefits of Preventative Maintenance Optimization
    Posted 14 hours ago
    I think you're thinking about it the right way, and you've put your finger on the tension most teams run into.
    Condition data on its own often only tells part of the story. It can show that something is changing, but without operating context it's easy to misread significance, degradation rate, or what's actually normal.
    The reason I emphasized early condition observations is that they're often the weakest link, even before performance data comes into play. In many cases, insight is lost not because operational data is missing, but because early signs of degradation are captured inconsistently or without enough context to connect them to eventual failure.
    Where this really diverges is whether the goal is better preventative alignment or true predictive capability. Predictive systems require far more data and discipline to be reliable, and I've seen teams chase complexity before stabilizing the basics.
    Once early condition evidence is captured consistently and tied back into the CMMS, digital sensor and performance data tends to become much more meaningful.
    Nick Bell
    Founder
    Duallo
  • 8.  RE: The Benefits of Preventative Maintenance Optimization
    Posted 21 hours ago
    Computerized Maintenance Management System CMMS optimization and a relationship to PMO
    A CMMS has been associated to "solving all maintenance problems", but in reality, a CMMS is only as good as the maintenance organization uses it. I like to compare it to file cabinet organization, being, both are only as good as how they are built, organized, used and maintained. Having a best-in-class CMMS is a "living document or requirement", to capture and maintain all asset data. All too often CMMS's are designed for accounting purposes and not for maximum maintenance/asset optimization.
    In reality, the best CMMS is a "one stop shop" for all the information the maintenance organization needs for quick and efficient asset information location, leading to best-in-practice asset reliability. Listed is a small snapshot with my real time experience challenges.
    1. Who is the "Gatekeeper" and are there written standards for specified CMMS use including rules for specific job positions whom interact with the CMMS? If new personnel interact with the CMMS, will they make damaging changes as to what they think or like; Or will they be required to follow the specified standard and rules. Can it last the test of time and personnel? Is a Reliability Engineer the Gatekeeper?
    2. Are all the assets listed in detail? Including all asset nameplate information and exact location the asset is located? Is all activity on an asset captured in the CMMS? As a leader, the first place I would go when I needed to review, order parts, look at failures and examine actual to KPI performance, PMO etc. was the CMMS. Also if you are informed of a failure, are you required to waste time to travel to find the nameplate data and was the asset easily located to find, vs. instantly finding the information in the CMMS?
    3. What is your maintenance strategy for your CMMS? What is your frequency of CMMS review/refresh? What is your most to least important/critical asset and how do you build your Bill of Materials (BOM), manage of change (MOC)? Are you capturing your transition to Predictive Maintenance? As a planner I needed to know most to least importance of assets so I could correctly apply the Ranking Index for Maintenance Expenditures (RIME) methodology for work order planning and scheduling. I also quickly needed to find parts on the asset and to what vendor.
    4. Is your CMMS a part of your EAM to enable work order building directly to the asset, including requisitioning parts through the work order directly to the asset? As a planner I could capture and improve all my planning work directly to the asset; including shopping in the BOM for parts, stock and non-stock, making repeat work order creation/ordering a breeze. And capturing all parts, labor and material movements for total cost to the asset.
    At this point, I hope you can see the importance of CMMS data accuracy and strategy. And how this can make real time PMO optimization a reality.
        In this discussion we only touched the tip of the iceberg and the importance of a Best-In- Class/Practice CMMS.
    Thoughts?
    Terry Alexander
    Charleston SC
