Do you have any way to monitor the oil level in the sump where the submersible pump is located? It is possible that air is getting into the pump, and the time lag is caused by the pump momentarily "losing its prime" and/or introducing air into the lubrication lines.
I sincerely hope this helps.
Daniel K Corman, CMRP
Houston, Texas, USA
