Thank you for your insightful responses!
1) The maintenance budgeting exercise is being done on an annual basis. We are working towards a zero based budgeting- there is a tendency to take the previous year figure and truncate the value in the budgeting exercise. The zero based budgeting will try to address this issue.
2) Due to pressure on the costs, instances were observed wherein workarounds were made, since the original spares were not available on time. This has led to expensive repairs during the course of operations over a period of time.
3) Criticality analysis for the plant has been done. The asset ranking has been done based on the most critical,critical and non critical equipment's. All the needed spares are being ordered with priority being given to the most critical and critical equipment's.
4) The PM program is more of a time based system- we are in the process of doing condition appraisal of the critical equipment's. Refurbishment plans are being made on the basis of the condition appraisal-which at this stage seems to be more towards machine rebuild and capital overhauls-which were neglected as due to budget pressures.
5) A rudimentary CBM plan is in place- which involves measurement of vibration using a portable analyzer. This is giving early gains. In line oil filtration has also been started. We are getting improvements in terms of reduced oil temperature. Heat exchangers are being serviced in this process as well.
At the initial stage,there is an outflow of money, which is needed for getting the plant in a needed shape. Going further, we are in the plan of circulating the gains made by maintenance practices- such as reduced oil consumption and improved uptime on monthly basis.
I would like to thank Mr.Ron Moore on his pointers towards precision maintenance. There are definite gains that can be had through precision maintenance program. As Mr.Jesse Day rightly pointed, the existing PM program seems to be more of a time based schedule. FMEA is being planned on the most critical equipment's- to start with. We shall be upgrading the checklists as the output of the FMEA. And thanks for the input on the sensors-Alex.
The plant is in a client facility wherein we are providing maintenance services and we are looking to improve reliability and uptime through the adoption of best M&R practices.
Srihari
Srihari R,
Manager-Asset Management
Thyssenkrupp Industries India Ltd
Sent: 11-22-2023 11:12 AM
Subject: What are some strategies for reducing maintenance costs without compromising reliability?
Hi,
Maintenace costs usually attributed to several cost factors:
- Labour
- Equipment (Capex)
- Integration Costs
- Quality of condition monitoring data
I ran into a very interesting solution that helps dramatically reduce several of these factors.
https://tractian.com/en The beauty of their solution is that they give you the sensors for free, there is no integration with IT department because they transmit all the data via a 5G gateway and they only charge you for the condition monotiling data.
What really stood out to me was the quality of the analysis they perform. Since they have thousands of sensors out there, they can identify vibration patterns using AI and they really give you the prescriptive advice that lowers the maintenance cost and prevents costly downtime. If you want more information feel free to email me directly.
Happy Thanksgiving.
Alex Aharonov
408-476-8163
